Any kb with white LED backlighting?
JSquid
I've had a couple with blue and both sucked, not bright enough. I've got a dell laptop with white LED back lighting that works really well so i'm looking for a keyboard with the same. I think blue LED is just a gimmick and not usable in real world situations due to the general weakness of the light that comes through the keys. if there is anything but pitch black in the room blue sucks.
tried this with a razer keyboard? i have the lycosa, backlit blue. comfortable to look at in any light. i imagine a white backlit kb would be painful to look at in that same pitch black room, without a dimmer switch :p
http://img.photobucket.com/albums/v295/utspyder/IMG00002.jpg
yeah i had that kb. i don't sit in a pitch black room and that is the problem. White LED backlighting is just easier on the eyes. If the blue was brighter i still think i would have an issue. white is far more readable than blue.
The Logitech Illuminated keyboard has white backlighting, but I'm not sure if it's LED.
I definitely agree that white backlighting is best.
Deck Legend - Frost
It's super fucking awesome. All the keys are lazer etched or whatever the fuck so it shows through the keys very clearly. It has 7 levels of brightness and it can turn off. I run it on the lowest setting and it's plenty bright.
do you think they have an incandescent light bulb in there?
they actually capture fireflies in a jar, then squish them under the keys
