Any Intel 975XBX users?
RebuL
Anyone else out there have a Intel D975XBX mobo? I want to know if you get a bunch of 2 digit codes on the bottom right corner of the screen while your system is booting (during POST). Everything seems fine...but I've never seen this before (Ive always built AMD systems). I trying to find out if those are error codes or something...of if they are normal.
Thanks!
Yes, but I don't know what they are. Don't believe they are error codes as I've had no problems.
