- Dec 9, 2000
Found it on NVs site, but nothing pointing to what it is.
If I had to guess, generic marketing render of a case. But I suppose if they are selling PCs, then it might be a generic case they comissioned for their own use, maybe from Tt, corsair, etc.
Looks like there is plenty of room for longer GPUs, in this "Hypothetical" case. You can plant the GPU support at the end of the power supply area before the slope. it doesn't need to be at the end of the GPU.It's "ok", the "bad" angle thing on the bottom (psu area)... doesn't make any sense. The "curve", which from that angle doesn't look seamless, maybe "ok", just not sure it's worth anything (style points?? eye of the beholder?) Other than that... I just see "yet another". Possible it means a case that can really only handle lower end FE edition (shorty) Nvidia cards (btw). I mean, there's "some room", just not enough for many (?). GPU support would go down "the slope".
Yeah, what is pictured is a very short GPU. Still, the slope doesn't make any sense.Looks like there is plenty of room for longer GPUs, in this "Hypothetical" case. You can plant the GPU support at the end of the power supply area before the slope. it doesn't need to be at the end of the GPU.
