Any Hope/Suggestions
locutus24
I started a case modding project with a free ctl case that i received, was wondering if this is woth continued effort.
Hope this is in the correct form
Also how could i get the plexi to be on the inside
I am certainly no expert but maybe clean the edges up a bit (sand them down so they are not so rough looking). To get the Plexi on the inside, just glue it on the inside.
You are painting after your done cutting it up right?
Well im hoping to paint it just so long as it would be cheaper to fix this up, in the place of purchasing a new case.
What is your budget? You have to factor in time as well when doing paint jobs on cases, as it takes at least 2 to 3 weeks to get a pro finnish on a case, and that is if you have good weather or a well veltilated indoor place to do it.
You can get really nice cases for under 100 dollars. Very nice.
Ok well my budget is how much work im feeling like doing, most days i try to do none. Just buying a pre-modded case is alot of work, well thinking about that i guess i dont want to mod it out anymore. Well im going to move this to FS forum if anybody wants it.
