Any good deals for a basic vista PC?
Status
Not open for further replies.
LBFlashWiz
My old man needs a new computer for his work.
He wants a decent flat screen, 2Gb ram and vista biz edition.
Anyone recommend a complete system <$600? Dell w/ coupon> ACER?
Thanks
I’ve done a bunch of work on Christmas PC’s with Vista installed from the factory. Most of course is getting rid of the trial ware and tons of assorted junk that just wastes space etc.
While I am a really big fan of Vista I have to be honest with you. If that is your price range and you want pre-built grab a Dell or Gateway or HP and I think you will find they all now offer the XP substitute for Vista. The reason is simple, like it or not Vista loves power. While it will run on a minimum specked machine even with everything turned off its no fun. Boot takes too long, program loading takes too long etc.
I’m not saying it’s not workable, just that it’s not particularly enjoyable.
On the other side if you get a fast dual core and 4 gigs of ram and a fast hard drive then things change and Vista is wonderful to work with in fact I’d recommend Vista 64 at that point.
After about 35 machines this past month, all factory fresh, I’d have to stand by my recommendation to any customer asking me about current choices, unless your DAD is a full blown gamer, then your budget won’t make it happen either way;)
Status
