Any external cases for single 22TB drives?
jordan12
I would like to get an external USB drive case that would support 20-22TB drives. My current one does not support even 14TV drives.
Recommendations?
As long as it supports LBA48, which any decent unit should then you should be fine. There are craploads of shucked drives out there, you can usually find empty (No Disk) enclosures from Seagate and WDC on ebay.
Just make sure that the plastic clips holding the case parts together were not broken when the drive was shucked.
Just be DAMN SURE to avoid anything made by O R I C O. I have some of their 3.5" external drive cases and they are all CRAP.
