silverphoenix
- Feb 15, 2006
I'm trying to see if I can run 64 3mm Leds off a usb port. Now the LEDs are rated at 3-3.3V @ 20mA, USB port can handle 500mA @ 5v.
Will splitting the circuit into 2 parallel circuits with a 10ohm 1/2watt resistor for each suffice to run each LED without drawing more than 500mA? I know this will drop the current flow through each LED to about 7ish mA but that is fine.
see my expert diagram drawn in Paint below
