Any downside to lower voltage?
computater
I think my ram is holding me back since it's only pc3200, so I've been somewhat content just running my opty 165 at 2.4 on stock voltage. Decided to play around and found that I can run 2.4 just the same at 1.3 vcore. (I may try lower later) Any downside to running at the lower voltage?
The only possible problem is decreased stability, but if it passes prime95 for a day it's probably fine. Undervolting has a lot of advantages.
There is only one real potential risk: not enought bias voltage for the protection diodes for the memory controller. Even then, there's some speculation that the Vdiff (VMem/2 - Vcore) has to be greater than 325mV, but the only failures that have proven this out seems to be on the higher BH/VX mems running at 3.0V+
Otherwise, I run undervolted all the time:
http://i59.photobucket.com/albums/g319/stranx44/sp04-1292.jpg
http://i59.photobucket.com/albums/g319/stranx44/sp04-1455.jpg
http://i59.photobucket.com/albums/g319/stranx44/sp04-1938.jpg
http://i59.photobucket.com/albums/g319/stranx44/sp04-2261.jpg
Nope, if it's stable thiers no problem runing lower voltages, worst thing that can happen is it won't post and you will have to clear your cmos.
Anyways I have played around with my 3800+ volts on different speeds and found the lowest stable volts at select frequencies. (Idle load/Both Cores 100%)
(Room Temp about 25C)
Less then 1 volt ->won't do anything
1Volt-1.8Ghz (30-36C)
1.05Volts- 2Ghz (30-37C)
1.1 Volts - 2.2Ghz (30-39C)
1.125Volts-2.3Ghz (30-41C)
1.2Volts- 2.4Ghz
1.3Volts- 2.6Ghz (32-46C)
1.4Volts- 2.7Ghz (35-52C)
1.5Volts- 2.8Ghz (40-60C) *Not Stable*
Currently I'm just using the 1.1Volt@2200Mhz one though.
I using a Arctic Cooling Freezer 64 with OCZ thermal paste.
Being a noob, I don't know if you'll come back to this, but your ram holding you back is no excuse on A64. Just throw in a divider and keep going. RAM bandwidth doesn't hurt A64 much at all so if you're not opposed to going higher go for it.
On the undervolt, the others have your advice covered-lower the better. Less heat, less energy waste, quieter. Some people do this on purpose for HTPC's and silent or very quiet rigs.
