killingfield1975
- Sep 18, 2006
shouldnt they both run equally the same? or would Vista 64 be faster?
I actuality, they run about the same, performance wise. I do believe if you had 4 GB of memory, you might see Vista 64 eek out a slight advantage under a heavy heavy load.
EDIT: You might want to revise your signature to the rules...before a mod does it for you!
Unless they've changed, you're limited to ten lines.
