Any Difference between HDMI-DVD cables?
Tri
Is there a difference between HDMI-DVI cable and HDMI-DVI-D cables?
I ordered Belkin HDMI-DVI-D PureAV silver series video cable and received a Belkin PureAV HDMI-DVI video cable? (it says 720p- 1080i). Now are these two cables identical or did they misship/misadvertized?
Dont be fooled by expensive cables. A digital signal is a digital signal.
A $5 cable will deliver the same signal as a $100 one.
If thats true what about the silver connections and gold connections. gold should
be better signal?:confused:
At long distances, higher qualities will help maintain a connection. However, digital is digital. There is no degradation like with analog, so if you get any signal, it is a perfect signal.
Gold helps prevent corrosion of the connectors. It has nothing to do with signal quality.
