Any decent really small LCDs?
nicholarse
Hi guys, I'm looking for a really small LCD to fit under my dell2405 so up to around 6.5" high - I was thinking something like a 7" display. I was to use it for things like Foobar 2000 and the like. Another thing - I would like it to look quite stylish to fit in.
Cheers, Nick.
Here is my setup:
Xenarc TSV 7"
Touchsceen, rgb, composite input, $400 can be used in car, computer & TV
That's a cute little display you got there. But a shrap aquos, that is just sweet.
And to the OP,
What are the benefits from having alittle display over a big display ?
IMHO the Hami lcd's found on ebay are the best 8" lcd you can buy. Decent contrast and refresh for a small lcd and true 800x600 resolution. My friend bought one upon my advice and it's little picture is brilliant imho.
http://cgi.ebay.com/ebaymotors/HAMI...ryZ38650QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ebay resller banankong
or
http://cgi.ebay.com/HAMI-3-in-1-8-T...oryZ3698QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ebay merchant fencolo
- 300:1 contrast
- 25ms refresh
- true 800 x 600 resolution (it can scale down a 1024x768 down to 800x600) (more pixels than a lilliput btw)
- TV tuner + remote + cables, might need to buy a cheap $2 coax adapter at radio shack.
- VGA, svideo and composite/coax input
- The lcd is strippable for mod use. It Might need a 20pin 5pitch fcc extension cable.
- Around $170~$180 shipped depending on the re-seller
