Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
as long as your ram speed is faster then your CPU for overclocking
basically DDR2800 is good for most CPU like q6600.
sometimes you may see some performance gain running your ram faster then your cpu FSB but i dont think it will be something that makes you go WOW!
and even before you didnt need stellar ram, just ram usually faster then your CPU so when you overclock, your RAM isnt the possible bottleneck stopping you from overclocking, or needing to run some ratio.
