Any ATOM boards have built in RAID1?
3DChipset
I was thinking of building a small RAID1 Home server, but I've noticed none of the chipsets say RAID through the northbridge. Any ATOM boards have built in RAID support?
To my knowledge no Atom-based boards have RAID support. They're meant for basic, small systems with low power-requirements. They don't even include anything beyond a PCI slot for this reason.
You could use Software RAID, of course. RAID 1 should be fine, 5 will put a bit of strain on the CPU.
Are Nano boards an option for you, or else a Mini-ITX AMD-based board? They're generally more full-featured, and (especially in the case of the AMD board) a lot more powerful. AMD chips in general underclock quite well, and will give Atom CPUs a run for their money.
Yeah, Nano-ITX would work. I'm looking for low power boards. Basically this is what I'm going to be doing. I need a board that's capable of onboard RAID1. It's just going to be using Windows XP Pro. No software on it, just setup as a file server to be connected to my network. Not sure how much CPU power you need for doing RAID1 file serving.
Going to be using 2 WD 640GB HD's in a RAID 1 setup. :)
Thanks for the help
RAID 1 in software takes very little CPU time compared to the time of the Pentium 1, when RAID 1 in hardware was something useful :p File serving mostly needs memory, depending on how many users it'll be serving simultaneously.
I meant Nano as in the CPU, BTW :) Those come on Mini-ITX boards as well. The AMD option will most likely be cheaper, though.
My Windows Home Server is a Atom 330 with a Promise Sata card- low power, 2gigs ram is more then enough, and close to 9tb.
