any 7.1 wireless speakers?
*laughs*
What do you mean 'wireless'?
You would still have to plug all the speakers into an OUTLET at least... o,o
Its much simpler to, instead of plugging seven speakers into seven wall outlets so their own internal amps can power them, to just have a set of speakers plug into ONE amp, which is plugged into the wall and plugs into your sound card.
Do you want wireless headphones? That can give you full spherical surround sound....
but why are you wanting any sort of wireless with a COMPUTER setup anyway?! hellooo... aren't you going to be sitting in front of the computer while you use it?
there's several solutions out there with wireless rear speakers... off the top of my head, i'm having a hard time thinking of one that is wireless all the way around...
none of them are gonna deliver very good sound quality... but if wiring is gonna be that much of a problem, i suppose they'd work...
Gavinfoxx said:
*laughs*
maybe he doesn't want wire stretching across his room/wall...possibly..
