Any ~600W SuperFlower <160mm?
wabbitseason
Hey fellas, I've been looking around for a SuperFlower-based PSU for a while now. This search has been seriously hindered by the lack of information on which companies actually use SuperFlower PSUs. Basically, is there anything like what I'm looking for (~600W, less than 160-165 mm deep) out there?
I know the Rosewill Capstone and Kingwin Lazer series both use SuperFlower, but are there other models from other companies which do too?
Thanks much!
Some of the EVGA PSUs are made by SF but they're pretty deep as well, Seasonic platinum is probably your best bet for a smaller high quality PSU.
Yeah, the EVGA Supernova G2 line is the Superflower Leadex platform and gets outstanding reviews. Not sure of the dimensions though.
I bought a 750 model based on Jonny Guru giving it near all 10's. Its 150mm wide and 180mm long (plug side to connector side). Not sure which one youre considering "deep" though but if it fits, its maybe the best one on the market considering its price, $110 shipped.
I'm trying to fit it into a Silverstone TJ08-E, which mounts the PSU opposite the optical drive. I guess by "depth" I mean ACplug--DCConnectors distance. I had checked out the EVGA G2 line but there's just no way I can fit the thing in the case.
For space constrained systems, the Silverstone Strider GS series would be your best bet.
I appreciate those suggestions guys but I'm really looking for a Superflower-made unit. I can make do with 160-165mm (6.3-6.5") depth, which is about average PSU size, I just can't work with the 7" or even 7.5" ones.
Thinking I may just suck it up and go with a Capstone, but just wanted to see if there was another alternative besides Kingwin's stuff.
When you restrict yourself to a certain brand in computer hardware, you only hurt your wallet.
All the Superflower Leadex psu's are 200mm long. If you can manage with a non modular psu then the Superflower Golden Green HX are only 145mm deep.
Jeff: That CM 650 PSU looks pretty nice. Only a 2-year warranty? That kind of sucks. I'm going to try & find a review of the V650 now.
Looks like a 5 year warranty. I wasn't able to find any useful reviews of the V650. One video teardown which was pretty useless. Techpowerup reviewed the V850 and was very impressed, especially by the fan, but the V650 is a completely different beast (much smaller, different fan, only semi-modular). Their naming is pretty confusing. I'd have called the compact lower-wattage PSUs something other than Vx50.
