Any 27"+ 16:10 displays?
Artex
Hey all,
I have a 25.5" Asus LCD that is getting little long in the tooth. What I like about this display is the extra height provided by the 16:10 aspect ratio. Looking around though, most new panels are all 16:9. I'm looking for something that would be 16:10 in the 27+ " size at 1080p or 1440p with G-Sync to match my 1070. Does such a monitor exist?
The equivalent of 27" 16:9 was generally 30" at 16:10, considering the 2560x1440 vs. 2560x1600 disparity. You generally lost resolution and screen size going 16:9 until 3840x2160 (4K) displays started becoming a mainstream thing.
You can still get a 30" 2560x1600 monitor if you look around, but you can forget about getting G-SYNC and a refresh rate higher than 60 Hz since most of those were generally pitched at offering better color reproduction for professional use, alongside lots of desktop real estate.
Good info. Thanks! I'll hold onto this one as long as I can then most likely move to a 27" 1440P GSync 16:9 panel down the road.
