Any 20x24" LCD setups?
cnick79
Does anyone have pictures of a 20x24 or 20x24x20" LCD setup? I have a Dell 2405 LCD and I'm thinking about pairing it with a non-widescreen Dell 2007. Both have a vertical resolution of 1200 and if my measurements are correct they should be pretty darn close to actual height. I see so many 30" LCDs flanked by 20" widescreens so how come no 24"ers flanked by 20's?
A friend on mine has a dual monitor setup consisting of a 2407 and a 2007FP non-widescreen. The height of the 2007FP comes up to almost the same as the 2407 and looks like a clean and neat paired match.
My own setup is a 2407WFP + 2007WFP.
Do you have pictures?
The other option is going with a 4:3 17" in portrait
Or if somebody could tell me what these side monitors are, then that might work too.
5:4
17" in portrait
edit: just noticed that both post were by the same person ^^;;;;
The ideal monitor size to match a 24'' would be 4:3 21'' but these usually cost more than a 24'' one..
You can use http://www.tvcalculator.com/ to compare the heights of monitor sizes that aren't in portrait. just punch in the numbers.
BTW I'm sure there are a few 20'' next to 24'' in this thread http://www.hardforum.com/showthread.php?t=862341&page=538
and over here
http://img48.imageshack.us/img48/2743/dscn04906kg.jpg
