Antivirus
Discussion in 'Operating Systems' started by John S, Dec 21, 2018.
  1. John S
    John S n00b
    58
    Nov 27, 2018
    Can you guys recommend an AV that is light on resources and uses minimum amount of memory. I have tried suites but they tend to slow web pages loading. Is it best to use just an AV without the suite with windows firewall.?.
    Thx
  2. thebufenator
    thebufenator [H]ard|Gawd
    1,055
    Dec 8, 2004
    Lightweight == Windows defender
    Domingo, Spartacus, Jim Kim and 3 others like this.
  3. FNtastic
    FNtastic [H]ard|Gawd
    1,269
    Jul 6, 2013
  4. Mazzspeed
    Mazzspeed [H]ard|Gawd
    1,414
    Dec 27, 2017
    You're not going to get any lighter than Windows Defender..
    Jim Kim, pendragon1 and thebufenator like this.
  5. Executioner
    Executioner Limp Gawd
    292
    Apr 22, 2015
    You did not mention cost - if you wanted free or a paid program. Defender is free and will work only if you are smart where you surf. You can also get Malwarebytes and perform manual scans so it does not run in the background.
    For me, I can't take a chance and I have ESET Internet Security and Malwarebytes that I paid for. Why, because I may go to risky sites. I'll leave it at that. ;)
    Jim Kim likes this.
  6. SvenBent
    SvenBent 2[H]4U
    2,657
    Sep 13, 2008
    i use malware bytes and dr web cure it as scanners
  7. stolikat
    stolikat n00b
    53
    Sep 26, 2010
    Bitdefender free.
  8. pendragon1
    pendragon1 [H]ardForum Junkie
    11,177
    Oct 7, 2000
  9. dr.stevil
    dr.stevil [H]ardForum Junkie
    9,095
    Sep 26, 2008
    ESET NOD32
    reliable and fairly lightweight (compared to others at least)
    Eradan likes this.
  10. B00nie
    B00nie [H]ardness Supreme
    7,812
    Nov 1, 2012
    NOD32 used to be the top choice but I've read its quality has dropped.
    pendragon1 likes this.
  11. Jim Kim
    Jim Kim 2[H]4U
    3,173
    May 24, 2012
    McDork likes this.
  12. fightingfi
    fightingfi Look at Me! I need the attention.
    2,409
    Oct 9, 2008
  13. B00nie
    7,812
    Nov 1, 2012
    I haven't run an active AV or malwarebytes in years. Sometimes I wonder why people tolerate having to live in uncertainty and see all this trouble.
  14. KG-Prime90
    KG-Prime90 Limp Gawd
    251
    Apr 29, 2013
    I use AVG free right now, Bit Defender before, and Avira before as well as pretty much tried every other one in the last few decades. But those three are light enough, no performance impact worth mentioning, basically because it's set to not not really actively scan every exe or file that i already know is safe on my machine. It's in the lightest setting and it's really simply a backup to addons for web safety ( it does actively scan the web) and for downloads/occasional torrent.
    And where does it pop up and terminate connection 99.999% of the time? Google Images. And no not porn. At all, actually, hardware or maybe nature images/wallpapers, "harmless" shit like that. And i'm not searching google images daily, but it seems every time i do, it happens at least once. So yeah, false positive or not for what it's worth, just the fact that it does pop up like that and terminate a connection on occasion even though i also run ublock, no script, an anti miner, https, i keep it.
    You could certainly raw dog it if you have addons and your browser "mostly" locked down. But i don't see any pluses to it, and any decent pc in the last 10 years it's not degrading your performance, especially if you run it basically mostly "off" for what it's worth, just get one that has those kind of options.
  15. B00nie
    7,812
    Nov 1, 2012
    Antiviruses are like a broken condom. Kinda protects but there's always a hole.
  16. Jim Kim
    Jim Kim 2[H]4U
    3,173
    May 24, 2012
    I use free Kaspersky with pro malwarebytes.
    FYI Had to enter ~15 exceptions in Kaspersky for it to play 100% nice with malwarebytes.
    It kept turning off malwarebytes real-time protection, the exceptions fixed it.
  17. Jim Kim
    Jim Kim 2[H]4U
    3,173
    May 24, 2012
    Not everyone has your index finger, maybe you should clone it.;)
    Chuklr likes this.
  18. B00nie
    7,812
    Nov 1, 2012
    It's easy, the magic fingers don't use Windows.
    Jim Kim likes this.
  19. Spartacus
    Spartacus [H]ard|Gawd
    1,917
    Apr 29, 2005
    Use Defender but then setup a VM for the internet combat zone.
    If your VM gets blown up, just restore it and you can get back to your "research".
    Performance is NOT up to par with Hyper-V. I use the free VMware player and
    network, streaming video, and sound all work fine.
    Password protect the VM and call it something like Win-7 Test so your family
    won't find your donkey-midget pr0n when you die.
