I found this so far, but I doubt that is the right port since it's for Apple displays and you've said it came out of a Dell.
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=pinconvid_apple_studio_disp_15
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=pinconvid_macintosh
http://en.wikipedia.org/wiki/Game_port ?
Lil weird for it to be on a video card, but it sounds like that may be it. Generally used for joysticks.
The connector (HD15) is for old fixed frequency monitors. Back in the day, VGA monitors came in fixed-frequency and multisync. If you've ever seen a monitor sit there and click while a game is loading, you've seen it go through multiple frequencies and resolutions. Fixed frequency monitors operated at typically 60Hz and no other frequency. Old Sun, SGI, and other workstations used fixed frequency, so there was a large installed base at one time. PC manufacturers (like Dell) wanted compatibility with these monitors so that people could pull out old Sun systems and the like and replace them with PCs.
Rainbow runner, etc. are piggybacked onto the PCB and didn't connect externally.
It was used in conjunction with the "Rainbow Runner" Upgrade Card as far as I can remember. You could either piggyback a ram upgrade on your Millenium/Mystique or said Rainbow Runner video capturing / processing card which then used the mentioned connector via a special cable for V I/O
1-2 Reserved
3 Y out (luminance)
4 C out (chroma)
5 Composite out
6 Y in (luminance)
7 C in (chroma)
8 Composite in
9-15 Ground
