Anti-static strap
tsonka
Forgot to order one and gonna do some PC building.
I have lots of speaker wire, could I strip enough insulation off of the wire to be able to wrap bare copper wire around my wrist then attach the other end to the computer chassis. Would this work just as well, or is there somethign magical about $10 wrist straps.
I have built multiple systems and never have I used a static strap. If you can't get one do what a lot of people including I do just touch the power supply before you touch any more components to make sure you are grounded.
I wouldn't worry about using one, there are many greater dangers for a first time PC builder.
BTW, what system are you building?
This is just me but I never use one... never have. As said above, just make sure to ground yourself and you should be fine... Of course if you do have a little static problem and fry all your new shit... don't blame me:p
Seriously, stay off carpet, and you should be fine, just ground yourself.
I don't know if I'm grounding myself correctly, Do I have to leave one hand on the PSU while working? The way I do it makes me feel like a dork. I rub my hands on the metal of my case for about 10 seconds like I was washing my palms on a towel.
if your worried about just go to bestbuy and buy a strap its like 7 dollars
you just have to touch it once then your all set
Thanks for the replys. This will be my 3rd PC build but I have never used one and just figured myself lucky. Last time I built a PC some of my parts went on Back order and it took me a few weeks to get everything. To avoid that I have already ordered everything but the Processor and will overnight ship a processor when prices drop.
Q6600 processor
GIGABYTE GA-P35-DQ6 mobo
CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
Western Digital 250gig HDD (canabalized from present PC)
XFX 7950gt Extream Edition (canabalized from present PC)
Soundblaster X-Fi extream music (canabalized from present PC)
CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply
CORSAIR CMXAF1 Memory Fans
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
I have debated and debated Q6600 vs. E6850. I finally decided to go with the Q6600 because even though the 2 faster cores in the E6850 may be better right now, I expect this PC to last awhile and Im betting that in a year or so the Q6600 would be the better choice.
:D :D
Don't know why, but that really made me laugh....
Touching the case is fine.. all your trying to do is discharge any static electricity that may be stored in your body, that's it. It's not really something you need to make a big deal out of... Just touch your case or your psu and your good to go... Have fun!!
