anti static bags
Go to a local computer shop. I'm sure they throw away more every day than you'll need. They're probably not even worth shipping to buy online unless you need a lot of them.
Like jpmkm says, most local computer shops would be thrilled to get rid of some, more than likely for free. They can be bought on line on the cheap, as well, but you won't be able to buy one or two.....ten probably more like it.
Good Luck - B.B.S.
