Antec900 Fan wiring question
I decided I was going to try my own build so i just recently starting purchasing my components. So far i have the antec900, CORSAIR CMPSU-750TX 750W psu, crucial ballistix 6gigs ram, i7920 ..... Now i was just messing around to see how I was going to do the cable management and realized i didnt know where to connect the fans to. I looked at the psu cables and couldnt find any that would fit the fans connectors. I was hoping I couldnt get some help on here. Ill link my psu and the motherboard im planning to get to see if someone can tell me if i can just connect the fans to the mobo
CORSAIR CMPSU-750TX 750W:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&Tpk=CORSAIR CMPSU-750TX 750W ATX12V
EVGA 141-BL-E757-TR LGA 1366:
http://www.newegg.com/Product/Produ...VGA 141-BL-E757-TR LGA 1366 Intel X58 ATX X58
Any help is appreciated :)
Let me put on my psychic hat and read your mind, ....... "what kind of fans do you have?"
Are they small 3pin, 2pin, 4 pin?
I have the Antec 900 and it used standard 4 pin molex from what I remember. Unless you got the Antec 902 which is new version of that case which those may be different. In any case, please post a screenshot of the fan connectors you are talking about and I would be glad to look at them.
Nope.. they are not any different on the 902 case. I have the 902. I HATED the molex connectors so basically I found some old 3 pin motherboard header fan connectors, removed them from my cheapy throw away 80mm fans that I had laying around and swapped em in place of my Antel 902 120mm case fans (and the big fan on top). All is well now, in the kingdom of Antec 902. ..hahaha.
You won't be able to connect them to your motherboard. You can power them from the molex connector cable on the powersupply. (I had the 900 years ago and replaced my fans, (with 3-pin fans), so I could manage them using the motherboard headers.)
If you're looking for cable management idea for the 900, you might what to check out the sightly dated thread here:
http://www.xtremesystems.org/forums/showpost.php?p=1889983&postcount=1
By the way, Cable Management is why I'm changing from the Antec 900 to the HAF 922 for my build this week. Too much of a hassle to convert it. Plus I feel that the HAF 922 is a better designed case.
I will post a picture of the fan connectors when I get home from work. Thanks for everyones help so far.
connector on the right is from the psu and the left is for the fans
Another cheap alternative, might be running the fans (back and top) over the MB (at least there's room/a small gap in my 902 for this) and hooking them up to a fan controller, which keeps everything pretty hidden...
ahhhhh, dude thanks alot. I would have never looked at the back of it. So thats what i need to do right? Just connect those two cords together
