Antec TruePower "Fan Only" connectors?
minameismud
I just got an Antec TruePower 480W psu from newegg. For the un-initiated, there are two "Fan Only" plugs on the same string having only two conductors - yellow and black. I assume this is +12 and ground. They match standard molex for +12 positioning. However, I only get 5.2 volts out of those two plugs (checked with multimeter). The rest of the plugs are fine, it's just these two. The manual no-so-clearly states that these lines should supply 12 volts...i think. Any ideas?
Those are for fans, like it says.
The voltage changes when the PSU decides to change it; there's a wee temp sensor inside.
I prefer a fanbus...
They run off the temp control inside the power supply that also runs the power supplies fans. If it's putting out 5.2 volts then the power supply isn't sensing much heat so it's cut the voltage down to reduce noise.
when i first got my antec, i plugged in my ccfls to the fan only, no thinking, and then wondered for about 15 minutes why only 35 percent of the damn tube was lighting up. i suppose this could be useful, if you wanted a thermometer type lighting setup
