I was wondering if my PSU is adequate for my system, the last part I have comming in is a BFG 6800 Ultra oc so I cant test it for awhile. My system specs are as follows:
MSI Neo2 K8N Platinum MB
Athlon FX-53
1gb HyperX pc-3200
WD Caviar 200gb
Sound Blaster Audigy2 ZS
Lite-on 16X DVD-ROM
Lite-on 52X32X52 CD-Burner
BFG 6800 Ultra OC
Antec TruePower 550 Watts
I have 3 case fans (the 3 that comes standard with the wavemaster case, 2 on lower front, 1 in the back) and I am using the stock Heatsink and fan from AMD. The system will not be overclocked at all or modified in that way.
Athlon FX-53
1gb HyperX pc-3200
WD Caviar 200gb
Lite-on 16X DVD-ROM
BFG 6800 Ultra OC
