viperdv2k4
- Mar 7, 2005
viperdv2k4 said:hey, i just installed an Antec Truepower 2.0 480W... My voltages are --
+12- 11.85
-12- 12.16
The rest seem around perfect, but are these supposed to be off by this much? because i thought antecs are supposed to be super stable. Also, on my 20-pin main connector, one pin is missing on the connector. There is an empty square.. .is that supposed to be happening?
THanks
+12- 11.85
-12- 12.16
THanks
QFTSpectre said:Check the readings with a multimeter not the BIOS or software.
viperdv2k4 said:Ok, and what about the 20-pin main atx connector missing a pin?
viperdv2k4 said:It could be, but is it supposed to be?
looks good to meSpectre said:So I have been scratching my head trying to figure out why we are at cross communication here until I realized something. Your PSU is a 24pin PSU. So I guess you are using an adapter?
On a 24pin(BTX) pin number 13 is a 3.3VDC pin and pin 18 is a ground.
On a 20pin(ATX) pin number 13 is a ground and pin 18 is the -5v.
In a SFX connector pin 18 is removed otherwise it is like a 20 pin ATX connector.
So pins 1-10 on the 20pin and 24pin are the same. Pins 13-22 on the 24 pin match up to pins 11-20 on the 20 pin connector.
So you have the option of missing from what you have described so far:
20pin:
Pin 13-ground
Pin 18- the -5v
24 pin:
Pin 13-3.3vdc
Pin 18-ground
Pin 15-ground
Pin 19-ground
So I wouldn't worry but damned if I know which pin you are pointing too.
This is all unless i have f'ed my diagrams. Then Ice Czar will bitch slap me for a while.
EnderW said:looks good to me
Dude, not to be rude, but someone has gone to the trouble of posting pin out diagrams for you above, and you still cant figure out the pin number?viperdv2k4 said:Ok, my power suppply is a 24-pin but my motherboard can only support 20-pin. The power supply is backwards compatable, so it can support 20-pin, so the 4 extra pins on 1 side are detachable. The pin that is missing is 3 from the side where the extra pins are attachable, on the bottom row.
So, would that matter?
