Antec TP II...
distr0
... alright, everyone reccomends them so i think im going to buy one
i think the 430 should be enough but im trying to decide if the extra $25 is worth going up to the 480.
my current rig is:
athlon xp-m 2500 @ 2.4
abit nf7-s rev 2
radeon 9800 pro
1 gig pc4000
its going to be in a antec p180 case with 5 120mm fans.
also i will most likely be uppgrading to a socket 939 system with an x850 or something similar sometime soon.
the 430 and 480 just seem SO close in specs, why even bother having both models available?
will i regret saving the $25?
KrakenGuy said:
No. The 430 will do you good.
i figured as much... and it should still hold up if i decide to upgrade to a a64 system with a x850 as well right?
