Antec Three Hundred?
Oh wow. Thats awesome!!!
I find it a little strange that it isnt on "tons hardware"... or anywhere else
They also have a Twelve Hundred in the works...Bigger than the Nine Hundred...
But this Three Hundred is supposed to be able to fit all 8800 series cards. And it is a budget case. I am going to buy one and mod a window in it.
Next up, we have the Three Hundred, a value-oriented case that incorporates some of the design features found in Antec’s higher-end chassis’. Features include dual front mounted USB 2.0 jacks, as well as mic and headphone. Fans include a top-mounted 140mm fan, a rear 120mm and the option for a pair of 120’s behind the meshed and filtered front bezel. The interior really shows the sacrifices made for value pricing: gone are the dual-chambers of removable HDD sleds of the higher end cases, replaced with a simple throw-back optical and rigid HDD mounting system. The price point of this unit is expected to be in the neighborhood of ~US$60.
$60!!!!!! Im in for 1....hurry up and release...its either this or the Coolermaster 590.
This looks a lot similar to the Cooler Master Centurion 590. Now I'm not sure which one to grab. Is the Three Hundred already out? I know the Centurion 590 has yet to be in stores.
Its not out yet except for on that site, and they want $60 shipping because its in aussie land.
Does the 300 have more room than the 900? I remember that being a main complaint of the 900 - cramped, not enough room, and horrible cable management (outside of modding it yourself).
Its better than the 900 at least. Still not that eye catching though.
I would have definately gotten this instead of my 900 just because this one dosen't have a window... Its just a preference i guess of size and window.
just got this case, and its the best case ive ever owned, quality is amazing, i got it for $59.99 @ Frys, i have the centurion 590 as well, i like this one better because its a bit smaller and fits the same amount of hardware, my 9800GTX fits without any problems, ive paid over $200 for a case and i didnt like it this much, overall for 60 bucks, you have NOTHING to loose and a great case to gain, my 2 cents
