Just bought a Antec 300 today at Frys for $45. To take off the cover, I just pulled on the plastic bit and pushed it out.
A note for others with a TRUE 120, it fits in the case but you will have to remove the 140mm fan that is located on the top unless if you want to change the orientation of the TRUE 120.
