Starcrossed
- Sep 27, 2008
Have this case and it is awesome definately a good buy!
I have an Antec 300, but after using several other cases, it is no longer my top choice for a case in this price range. It lacks a cooler hole in the motherboard tray, lacks any semblance of cable management, and lacks a sexy black interior.
Consider these, they all have much better features:
HEC Blitz $35 fs
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121096
Rosewill Blackbone $50 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147023
Rosewill Destroyer $55 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147144
Rosewill Smart One $55 fs
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147120
Rosewill CHALLENGER $55 fs
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
NZXT Gamma $50 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061
NZXT M59 $60ish shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058
Thermaltake V3 $48 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133094
Thermaltake V4 $60 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133179
Lian-Li Lancool $75 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112238
Raidmax Atlas $60 shipped
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156247
The Antec will outlast any case on there except for the Lian-Li. Rosewill cases are garbage, you will bend the side panels if you look at them wrong..
