Antec SuperLanboy
djnes
This case looks to be a good one, and would be perfect for my wife's computer. My only question is, the front fan, appears to be blue. Is it the fan itself that's blue, or the front grill part? My wife loves purple, and if the fan is blue, I can swap it out for a purple one she has now. I realize this is ridiculous, but if she's happy, I'm happy...if ya know what I mean.
The fan is blue. The plastic part on mine also has a blue tint, but in alot of the pictures of the case that I've seen from the plases selling it, it isn't tinted. You should be fine; alot of people around here have changed the color of the fan easily and successfully.
it's not tinted blue. it's just very thick clear plastic.
here's some shots. I just finished up a build in a super lanboy.
http://www.hardforum.com/showthread.php?t=1072578
overall i'm happy with the case, but wiring it is a bit of a pain
Awesome, DisrupTer911. You're first picture is probably going to be the seller! She'll love the purple.
I like my superlanboy. I moved the front led fan to the inside to make it a bit dimmer at nighttime. There's a 3-pin connection for the front fan on the outside of the front bezel, or you can run the wiring through to the inside of the case yourself, which I had to do with a 4-pin fan.
Wiring is fairly easy. Put your hard drives in backwards so you don't see the connectors, and run molex connectors behind the mobo tray. ATX cable can go where the screw-drawer is, or behing the 5 1/4 inch bays if you use some cable ties to keep it from interfering with the drawer.
