The 1200rpm fans that came with the Super Lanboy seem a little weak, so I'd like to replace them with 120mm white LED Cooler Master fans. I'm also doing some medium overclocking, so I've considered hole-sawing two extra holes for 120mm fans into the case window. Is this overkill for a 3.0C at 3.75GHz (250 FSB) and a 6800GT at Ultra speed? There's only one 7200rpm HD, one floppy drive, and one optical drive creating heat besides those.
I installed the rear fan with the rubber grommets that came with the case, but then I took the fan and the grommets out. Problem is, I snipped off the ends before I realized none of the screws that came with the case seemingly fit the holes that the rubber grommets were in. Does anyone who's used a Super Lanboy know what kind of screws would be best for attaching a 120mm fan to the rear fan grill without using the provided grommets? I don't have any screws that fit both the fan and the screw holes in the case firmly.
