Antec Sonata PSU Upgrade
brownkc
I am finally going to make the jump to PCI-E. It looks like most top-end cards require at least a 450W PSU. My case has a 380W PSU. I think the Seasonic S12-600 would be a good upgrade that will hopefully last a few years (doubt I will go to SLI).
Are there any problems with fitting the Seasonic in a Sonata case? I remember reading about some quirk regarding the PSU when I bought the case. I can't remember if it is as simple as losing the ability to have the PSU regulate the case fan speeds or if it was a proprietary setup size-wise and other PSU's won't fit.
Your help is appreciated.
