Antec Sonata III HD LED?
Mr_Superstar
I have an Antec Sonata III case and I just installed the Intel Intel BOXDG33TLM motherboard. I just cannot get the HD LED to work. No matter how which direction I install the jumper the LED never comes on (and I know my disks are in use).
Anyone have any ideas?
Thanks,
Mr_Superstar
Can you connect it as the power LED just to make sure the LED is functional?
I figured it out. Unfortunately, my eyes aren't as good as they used to be. I installed all of the jumpers vertically instead of horizontal (or horizontal instead of vertical, depending on how you want to look at the board). The little tiny numbers on the motherboard weren't as clear as they used to be. Interestingly, the power & reset buttons still worked. I looked at the motherboard manual and realized I was doing it wrong. I just didn't have the manual when I was first building the computer.
