questions questions.
Well to start with, I haven't put together a comp or changed cases in a good 3 years. Recently I did a "budget" upgrade and bought an antec sonata and a new mobo/proc/ram. I went with the sonata as I was very tired of my old antec soho case with 6+ fans that sounded like a vacuum cleaner. However, I'm somewhat concerned about the cooling - I've just gotten things setup and everything is stock (including the stock hsf on my xp2700), my room temp is somewhere around 73F but my antec case temp is 98F/36C. I've got two hard drives, one optical drive, an old geforce3(next in the upgrade scheme), and 1 gig of Ram. Do these temps sound normal for someone running one of these cases with stock cooling setup in the antec sonata (e.g., the single 120mm fan)? My processor is sitting at 111F/44C idle.
thanks much for any input, just a little nervous about those temps (the case temp seems rather high compared to the room temp).
--ok, also, coming from the power supply of the sonata there is a small blue and black three prong plug that has a tag on it: psu monitor fan, currently this isn't plugged into a fan header on my motherboard but I'm not sure what the purpose of this is, the 120mm fan is plugged into the FAN ONLY molex connector coming from the psu--
--after running prime95 for about an hour now my temps appear to have peaked at 59/60C for cpu and 43C for the case, this sound right for stock cooling all the way around (no AS just stock amd hsf with "thermal pad"?--
