Antec Sonata - $59.99 AR @ Outpost
fastgeek
[H]ard|DCOTM x4 aka "That Company"
Came across this while browsing through Outpost and thought I'd mention it. IMHO it's a great case, at at $60 after rebate it's a damn good price too. Actually the only negative I could mention would be the front mounted USB port needs to be rewired with certain MB's, and that pretty Piano Black finish really likes to pickup finger printes... but other than that? Nothing. Great looking and damn quiet.
http://shop4.outpost.com/product/3558634
Regards,
fastgeek
Does anyone know if the PSU is compatible with nForce 4 Ultra motherboards? Thanks.
this is an awesome find. a solid and quiet case, plus the included "truepower" power supply is worth every penny.
shipping charge doesn't look that bad for ground. IMO this is an especially [H]ot deal for those within driving distance of a "fry's".
So, I can buy it at Fry's (physical store) and use the rebate from here? Or does Fry's and Outpost have the same price. Thanks.
I believe the supplied PSU isnt ATX 2.0 :(
The Fry's in Renton costs more than online, $69 after rebate, but no shipping.
If you mean a 24-pin ATX header, then no, it's your typical 20-pin. If you mean something else, be specific and I'll go look at the Sonata I have sitting in my garage. (I'm still sorely tempted to buy another one, but I'm resisting... or at least trying to! :p )
Regards,
fastgeek
The PSU is the older Truepower-1 series which should be ATX 12V 1.3 I believe. It is COMPATIBLE with NF4 motherboards, but not recommended unless it's a lower power budget system. The price is damn good even with an outdated PSU.
If you really like the case and want one more suited for a power hungry gaming A64 rig, then the Sonata-2 comes with an ATX12v v2.0 smartpower 2 series 450W PSU but you can't get it for $60AR :)
This is a great case. It is gorgeous. The PS will work on a lower end nForce system. I had to beef it up for my SLI setup. My one complaint. When I bought this the pictures showed that there was a cutout for 120mm fan to blow over the drive cage. The was nothing there. I had to break out the Dremel to get an 80mm in. It has a snap off faceplate on the bottom with vents, so it is hidden and looks good. Just be aware if you like air on your drives.
