Antec Solo, What To Expect?
The only problem I could see is some tower coolers may have problems fitting in the case, and long video cards could reach the hard drive bay.
System in my sig is running great with a thermalrigh ultra 120 extreme (which fits very tight btw).
I'm also a fan of the out of the box hard drive suspension elastics.
My only real complaint was the from 92mm fans instead of 120mm fans, but I fixed that with pliers and some imagination.
I have one. The cooling isn't to great, but it is really quiet and it looks great. I have an xigmatek s1283 in mine. It is a pretty sturdy case
For a mid case I thinks its good. I can fit a TRUE HSF in mine fine. It gets quite cramped with many bits. I bit hard to hide away numerous thick cables.
I'm going to get an Antec 1200 soon because I need some space to breathe.
It's a great case. Bought it locally on CL for $45. It's a great design but cooling could be better. I love the 3 ways to mount the HD especially the one with the strings.
I'm awaiting my PSU from a seller on [H] and a motherboard, then I'll be ready to build.
