Antec Solo or Temjin TJ04
Nnyan
Hello everyone,
Building my new system in the next few weeks and I've decided to spend more on core components (CPU/GPU/etc...) then on things like the case.
Anyway I'm looking for something with solid quality, mid-tower with a side window. I'm building a water cooled system and want it to be very quiet. I have a few questions.
Anyone out there know if there is a side window for the Antec Solo or even a DIY kit? How quiet is the Temjin TJ04 (if I go with this I'm planning using rubber grommets and such to make it quieter).
Also does anyone know if a 8800GTS will fit in either of these cases?
Thanks!
do you want your watercooling inside or outside the case? i don't think either is big enough for inside
