antec smartpower 2 500w: enough?
r_a_s88
would it be enough to power a 7800gt and 4000+ sandy core with a dfi ultra-d board?
any opinions would be helpful...thanks :)
yeah sig limit is 10 lines I think, might even be 8 :)
EDIT: Sorry to dig up old(er) thread, was searching and didn't check the date :)~
It is 10. And since the thread is up.......
OP: THe smartpower will work but if you have the xtra money consider the OCZ Powerstreams since you are using a DFI board.
Agreed here. Also, the 10-line limit on the sig is as viewed in IE 6.0 at 800x600 resolution.
