QFTShould work just fine, for about six months. That's about how long you can expect the capacitors in that thing to last with the lousy airflow it will be getting in a Dell.
That's if you do it stock; if you can find the fan control and bypass it so fans run 100% all the time, then i'd give it a year. Else, 6-9 months.
While you're at it, bling it up, redo it with a modular kit, and paint racing stripes on it.
It is.the guy i bought it from said it was modular.
well i installed it today...and working fine.
