Antec SLK3700AMB door removal
How do i go about removing the front door that covers your drive bays etc etc. the case is on my right hand side and the door blocks everything, and i want to remove it for teh time being but want to have the ability to replace it if need be. its like a smaller version of the generic chieftec cases in case you were wondering.
in the top corner of the hinge you push down the plastic on the door and slide out the door
edit : if that doesnt work check the back side of the bezel and look there you may have to bend the door to get it out
