Antec SLK 350 enough power????
i have athlon 64 3200 s749 with a bfg 6800 gt oc will this antec slk 350 that came with my landboy be sufficent power for it or should i consider buyin a new psu thanks alot for ur help if it helps i hae a gig of ram kingston hyper x and a 160 gb hd
It will be close.
How many Amps on the +12V rail can it do?
How many optical drives do you have?
it might but I doubt it..I am running a 3200+ a64, 6800 ultra, 2 80 gig hdd's 1 gig ram..etc..and its barely enough... and the 350SL would have a ahrd time..but I would try it anyways....antec's wont kill ur comp...the gt will just downclock itself if it's not receiving enough power..
thansk alot for ur help guys yeah imma try it first then if i gotta get a new one i will btw i have two optical drives as for how many volts its puts out i have no god damn clue went on the antec site and found nothing it came with the landboy case that i bought
I've looked up the specs for the similar SL350, and it delivers a maximum output of only 16A on the +12V rail. That may not be quite enough for your near-high-end setup.
