Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I looked at them at fry's It would be pretty fuggly with the top removed. THat's somewhat my problem with the case it doesn't look like there is much distance between the top of the board and that huge fan.
Personally I'd go with something like an antec if you really want airflow.
I *don't* want airflow, I want to stick the heating element of a phase change cooler through where that fan is.
Looking at some high resolution pictures of the case, it looks like the fan is not designed to be removed. I'll probably end up making some barebones motherboard mount.
