Antec PowerSupply + New Fan =?
DDrasus
My 1.5 year old antc true power 330 has been a superb supply, with right-on-the-money voltages everyday. however, the rear exhaust fan is making a loud ticking sound, its about to die. i really do not feel like shipping the supply back to antec, so i want to replace the fan myself. will this be easy, and should i do it?
It's not hard. I've been using PSU fans for a while. They're regular 80mm fans. You'll need to do some wire-splicing, as the fans in the PSU use a wacky connector, but other than that it should be a simple matter of taking out the old one and sliding the new one back in.
If you must open it, don't touch the capacitors; you can replace a fan, you can't replace your life.
My friend replaced his PSU fan just fine. However, he didn't know that PSUs held voltages even after they were off. I told him that they hold charges and he freaked out.
By breaking that sticker you are wasting 1.5 years of warranty. I would just RMA it.
