Im just starting to put together a future PC system.
Im starting with the power supply, Im looking at the Antec Phantom 500, which is available for purchase now.
I really like the 88-90% efficiency rating from the review at: http://www.silentpcreview.com/article241-page5.html.
What I dont like is the fan noise that it does have, 24 to 37 dBA. Ive listen to some sound samples, its a little too loud, not a silent power supply when the fan is running.
I was wondering if it would work to remove the fan and replace it with a Silenx iXtrema 92mm Fan (I like the Silenx 92mm better than the Silenx 80mm, I own both and the 80mm does have some noise, while the 92mm is silent and moves 36 CFMs of air, I can only hear it with my ear right up next to the fan).
The back of the Antec Phantom 500 easily snaps apart as shown here: http://www.silentpcreview.com/article241-page4.html
It also looks like the Antec uses a standard fan plug connector. I have a full tower case with plenty of room above the power supply to leave the 92mm fan stick out above the end of the power supply. I would only need to remove a small portion of the top of the supply where the fan would need to protrude upwards. I would permanently remove the plastic end cap.
With the Silenx, then this supply would be truly silent, and supply plenty of cooling at 36 CFMs, I could even use the lowest setting on the Antec Phantom 500, so the fan would run more often then and keep things cooler yet.
My future system would consist of the following main components:
2 GB of DDR ram
AMD Athlon X2 4400+ , maybe 4800+ (up to 110watts)
Nforce4 Ultra motherboard
Nvidia 6800Ultra Video (up to 75 watts)
DVD-Rom drive
DVD 16X +-R/RW burner
2 SATA-II Hard Drives.
Before I purchase, just wanted any opinions on the Antec Phantom power supply mod, should this work?
I just think the very silent nature of the Silenx 92mm (14 dBA), along with 90% efficiency would be a great power supply.
Thanks.
2 GB of DDR ram
DVD-Rom drive
Thanks.
