it all depends on which fans you useStalkerZER0 said:Can someone tell me if the new P190 is as quiet as the P180??
With the extra fans I suppose its noiser correct??
Also, which do you think is quieter.....the lian-li v1100 or the p180/190??![]()
sn_85 said:it will not be quieter than a p180 given that you use the same low speed fans. reason being that as you said, there are more fans and more area for sound to escape. this case doesnt have a well planned out airflow design rather it uses brute force, as in more fans and bigger fans. if you are looking for silence, stick with the p180 and plan ur airflow out accordingly.
StalkerZER0 said:Ok, well do you think the p180 is quieter than the lian-li v1100??
Sorry, I didn't mean to hijack the thread but I need the question answered.![]()
the v1100 has sound dampening on the side panels too, and is made of aluminum with less fans and has the fan coverssn_85 said:p180. steel and it has sound dampening materials all around the case.
~GoaT~ said:the v1100 has sound dampening on the side panels too, and is made of aluminum with less fans and has the fan covers![]()
StalkerZER0 said:Argh!
I was bout to order the p180 then I see this. So is the v1100 quieter than the p180 or what?![]()
Borgschulze said:I like the Dual Top Blowholes, and that's it.
I'd rather have my P180B.
Antec didn't fix the problem with the rear fan... it has clearance issues with the Karajan Audio Module on the DFI LanParty boards.
Ockie said:I don't agree. Antec said that they replaced the panels with a better sound dampening material and these fans are larger and spin slower.
StalkerZER0 said:Perhaps he has a point you all think? But more holes equals more places for sound to escape correct regardless of slower larger fans?
sn_85 said:whats the point in dampened side panels if you are going to put a fan hole in it? i mean isnt the whole point in sound dampening material to absorb sound waves and prevent them from leaking outside the case? instead you put a fan right in the middle of it. i dont care how big of fans or how slow they spin, when you have holes, sound waves will leak through it. How about this, what happens if i just cut out a 120mm hole on the top of the case and a 200mm hole in the side panel either have the fan turned off or not even put a fan there, will the computer be louder? more holes = more ways for sound waves to escape.
Ockie said:At some point you need a balance in ventallation and sound... sure sound will escape, if you have loud internal components... for those who are already silent, this will just add to the pleassure of more quiteness but adds the convenience of air flow.
How do you consider this "the middle", have you acoustically researched the case and detirmined that it's the maximuim point of escape? I'm going to trust Antecs findings and research over a couple forum comments about better handling of sound. Perhaps it doesn't do better, but damn well I'm going to believe them over a forum poster anyday, especially with the good job that they have been doing in regards to handling sound isolation and acoustics.
Better airflow = better cooling = better chance of running fanless or low fan speed cooling = overall less noise.
I don't know where you guys come from, but try to run say quad sli in your P180, tell me how loud it is after all the fans are on high speed to try to cool that furnace down... thats basically the logic.
StalkerZER0 said:Well, here are my specs that I have planned:
a8n-sli deluxe mobo
amd 4000+ with a thermalright xp90 (and soon to be delivered nexus 92mm silent fan)
3 gigs of ram
8800gtx from evga ACS version
2 optical drives
4 hard drives (2 SATA, 2 IDE) (plan to put them all in bottom of case to isolate noise?)
PC power n cooling silencer 750 psu.
I only want enough cooling to keep the components in check. Nothing for overclocking and no SLI.
The aim is for the system to be as quiet as possible without going fanless.
I just placed the order for the P180 and the silencer 750 and the nexus 92mm case fan.
Now I have to figure how I'm going to make this work.......with help from you guys?![]()
sn_85 said:how are u going to use 3gb of ram? might want to use 1gb sticks in dual channel.
StalkerZER0 said:Easy. Two 512mb sticks and two other 1 gig sticks.
In any case, Bbq are you telling me that I should still install the hard drives in the bottom rack but remove the bottom tricool fan?
Ok fine.
But your also saying to remove the upper hd rack and install a fan in the front section there?
What good would that do?![]()
Use rubber grommets for fans and hdd mounting. I don't hear anything but air moving, no fan vibration, fan motor, hdd seeks, nothing.DryFire said:Al is normally a bad thing when you are talking about quiet computers.
http://www.silentpcreview.com/article75-page1.html
Well if they used the 1cm they have, I wouldn't have that problem.Ockie said:Why should that be antec's problem that DFI doesn't conform 100% to the standards?![]()
No other board has a problem, so why should case makers cater to one board maker who likes to go outside of the bounds?
Borgschulze said:Well if they used the 1cm they have, I wouldn't have that problem.
I don't even use the rear fan, my radiator is there pushing air into the case.
It's the fact it doesn't fit. No need to seem rude about it, don't hate DFI so harshly, clearly you like Asus.
