Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
You've got about an 1 1/16" between the door and a flat bezel. I have a Zalman Fan Mate taped to the door and with the 3M double-sided tape included it wouldn't close, so I just folded over some masking tape and it clears it.
1 1/16" is pretty much it. My X-Fi console also clears it, but I cannot answer your question directly as some fan controllers have longer knobs than others.
Worst case, you can set the fan controller further back into the drive bay, but it wouldn't look as sleek.
