Antec P180b Lower Fan Bracket Installation
ilikecake
I recently got the Antec P180b, and I am installing my computer in the case. I removed the fan bracket from the lower chamber in order to sleeve the cables, and now I can't get it back on. Anyone with a p180b know how to do this? I am sure it is really easy, but I just can’t seem to figure it out.
make sure the 4 tabs are in the holes, then push, then push the thing that sticks out perpendicular to the fan, straight down. It should go click and lock.
Just like the person above said just line it up and push it towards the "backside".
If you still cannot figure it out step back from it for a minute and look at the design. The bracket is very simple and just L shaped so once it goes into the 4 holes it should be obvious which direction to push/pull to get it to lock in.
Out of curiosity did you get one of the thick fans or did they send you a thin fan? I saw a few others complaining they got a thin fan and I did as well, it was the same thickness as the other fans.
Wow, that was amazingly easy. Thanks for the info guys. The fan that I got is 25mm thick. Is that the thin version? What is bad about a thinner fan?
Nice to meet a fellow P180 user :D
The thicker fan on the bottom is really ment to move alot more air (cfm) then the thinner ones (mainly for fanless psu's) but if you have a decent psu with a 120mm fan in it, it'll be fine with a smaller one (the smaller fan will also give you a lil more clearance with your psu wires). With my p180 I moved the small intake fan from the main chamber to the bottom chamber and put the big one in the front intake of the main chamber that way I get alot more cooling where it counts (vid card, cpu,mobo). That 5 min mod lowered my overall temp by 2C.
***Tip*** You have to swap the bracket from the big 120mm to the thinner 120mm and vice versa in order for you to be able to mount them in thier new spots.. Took me a while to find that out lol :)
Also removing the grills over the top,rear,and front of the case helped alot in over all temps.
I actually never got a thick fan with my that I just ordered about a month ago, I saw another post from somebody else that had the same problem. *shrug* I ended up replacing all of the fans with some yate loons on a fan controller while keeping the CPU passive with a zalman cooler most of the time and it is dead silent :)
I did get the thick fan, but it's in my storage bin cause it would not fit with my 1kw power supply. On the top section I put 3 thick 120mm fans that I got at Fry's, these fans are not loud at all and push about 84CFM's each and put these in place of the thin Antec fans that were there originally. :p
