Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Really the case got pretty good reviews on everything except for the weight. I thought it would be the perfect case for my micro-atx i7 build. Do you have a recommendation of another case? I am building a new desktop here are the specs:
i7 920 "thank you Micro Center"
EVGA 121-BL-E756-TR Micro ATX
G Skill DDR3 1600 8gb (2x4)
OCZ ModXStream Pro 500w
Caviar Black 750gb
LITE-ON DVD/RW
XFX GTS 250
Does it have to be such a small case? I mean the P180 isn't a bad case. My biggest gripe was that you can't effectively cool the hdd's. And considering how hot the I7's get I would consider a larger case with better cooling. But that's just me.
It doesn't have to be a small case I am flexible regarding that. The features that sold me on the case were the bottom mount psu, the black interior "saves me the $60 on powder coating" and the overall design of the case. The other selling point of a small case is I currently have a server "full atx case" and a workstation "atx mid tower" under the desk and was hoping to not add another beast to the cramped workspace. That being said I don't want to get a case that jeopardizes the hardware because it cant handle heat efficiently. Function definitely comes first. One thing to note about cooling the HD is that I will only have one HD in this case. I have tons of storage on my server.
The Cooler Master 690 is really hard to beat at it's price point. But it might be a bit larger then what your looking for. The new versions have black interiors.
That is a great looking cases and has everything I was looking for. It is definitely larger than what I had in mind but if I ever needed to switch to a larger mobo later this would accommodate many more options than the P180. Thanks for pointing me in this direction dkev I will keep this in mind as an option.
