antec p180 questions
mystic demon
Was thinking of getting this case and had a few questions. I've read that some psu's dont have long enough cables and this case is picky on getting oen that'll work because of this. I have a fortron blue storm 500w psu and chaintech vnf4/ultra will it work fine in that case? Just wanted to know if anyone had experience with it. Also what are some of your pros and cons of the case? thanks all
I own one and give it a thumbs up, but with reservations:
It is a rock solid case, except for the flimsy plastic door.
The plastic/steel sandwich panels make the case easy to quiet, but the plastic looks like...plastic.
It is well built, but is mostly over-engineered with extra steel that doesn't provide structural support.
The parts that were under-engineered are with crappy breakable plastic parts are parts that you remove alot...like the side panels.
It's a case that can take a pounding, but is really heavy to lift and doesn't have good surfaces to lift with.
Has lots of decent 120mm fans.
A lot of well thought out small touches were added to help with silencing.
