thrawn86 said:there's no way the antec 900 can be a quiet case with all that mesh. plus, IMO, it is UGLY AS SIN.
p180(with front fan mod) hands down.
Sphere said:Is that statement because your running the P180?
I"m running the 900, and it really isn't noisy at all, if it were, it would have been sent back. If you want a *cooler* running system, the 900 will do it.
Guess it all boils down to what your after in a case......either way, good luck with your decision!
Sphere
thrawn86 said:I have no problems with the cooling ability of the p180. I've got every fan slot filled with a yate loon, and I plan on replacing my PSU soon (with a short model) so I can have 2x 120s in the lower chamber.
fake edit: its not as ugly as I previously thought, I'm just not liking that weird upward sloping top panel at all, nor the side window.
Just functionally, I like the p180 better.
Lets compare:
P180
-2x front 120 (with simple mod)
-top 120
-rear 120
-chambered design, removable cages
-front door
900
-2x front 120 (led)
-top 120 (or whatever size fan that is)
-rear 120
-ugliest side window in the history of pc modding. mount for insanely huge fan
The 900s 'advantage' in cooling seems dependent on this behemoth side mounted fan, and unless that properly ducted (and the remaining mesh sealed off) I can't say I'm a huge fan of that.
/me sets mode -!!!!!!
IntelOwnz said:yea right now i'm thinking the p180 just b/c it seems better built, it's quiter, the psu is actually seperated from the rest of the components, there's nearly no difference in price for me, it actually has some decent cable management features, plus tons of spots to hide cables, and it has enough room to fit all my components plus some more room to maybe mod in some extra fans....but hey ya never know, i'm not buying for at least two weeks, so we'll see how things go.
